2.5 inch POS rough country lift
Old Jul 29, 2014 | 05:48 PM
Dolanjohn1990's Avatar
Dolanjohn1990 is on a distinguished road
Default 2.5 inch POS rough country lift
so I am in the middle of a 2.5 rough country lift and I thought I was almost finished. I got everything put back together and noticed my steering linkage gets blocked at the differential when you try to turn right. My other issue is when I crank my t-bars I don't see any change in the adjustment. I know I mad all the cuts they instructed me to and as far as the T-bar am I supposed to have weight on the arms to get it to adjust? I'm very frustrated with this kit and would really appreciate some help.
Old Jul 29, 2014 | 08:05 PM
05canjimmy's Avatar
05canjimmy is on a distinguished road
i just did this lift 2 weeks ago on an 05 2 door. did you cut the top bracket off the dif and install the drop? and did you install the wedge on the passenger side? and for you keys did you put them on the correct part of the hexagon? when the key is loose on the bar it should be almost flush with the bottom of the cross member thats why you must compress them with a tool back into place so you can get the block that your adjustment bolt goes through back in. you need your knuckles connected before you put the tension on the keys as well.
Old Aug 6, 2014 | 07:14 PM
I did every thing to the T. I put the tires back on before I even tried cranking the Tbars.
tibby
Lifting Tech
54
Dec 29, 2015 11:13 PM
BackwoodsBogger14
Lifting Tech
Mar 26, 2014 08:45 PM
01blazer16
Lifting Tech
Jun 13, 2013 09:29 AM
priesman64
Lifting Tech
25
Apr 8, 2013 12:18 PM
abig84
Apr 6, 2011 08:00 PM
