2" Body Lift Issue
Sounds like it may be a loose plug wire? When you sprayed it, the carb cleaner may have gotten into it and caused it to stutter.
okay well here's my ideas:
1. DID you check your motor mounts yet?
2. DID you un-bolt the screw that holds down your brake lines on the upper fender well shock on the driver side?
3. Are all your radiator hoses on tight and clipped properly?
4. You might have pinched your fuel lines along the frame rails on the driver side.
DOUBLE CHECK everything, just did mine last sat. took 19 hours, but everythings perfect.
Okay. I'll check everything out tomorrow. Where are the motor mounts located? Yes, I took off the screw that holds down the brake lines on the driver side. Radiator hoses look fine and no loss of antifreeze. Ill check the fuel lines tomorrow. I cleaned out the EGR today, but no luck. It just really sucks that it's doing this now. I just had it running better than new the day before I lifted it. Thanks
i had the same thing happen to mine right after i changed the plugs an wires ... so i went an messed with the distribitor cap a it stoped haveing the ruff idel an hasent done it again...
What did you do to the distributor cap? I've made sure every hose is secure on it.
i would turn it off an move it around a lil crank it up... an it finaly stoped... an un hook a spark plug wire 1 by 1an put it back on just to make sure there all on good...
ComputerNerdBD
02-28-2010 11:30 AM
midnightmekanik
10-08-2009 08:32 PM
cide
03-23-2009 10:57 AM
