2" Body Lift Issue
Old Jun 10, 2010 | 04:38 PM
Frankiesurf's Avatar
Frankiesurf is on a distinguished road
Sounds like it may be a loose plug wire? When you sprayed it, the carb cleaner may have gotten into it and caused it to stutter.
Old Jun 10, 2010 | 08:55 PM
Dbam31's Avatar
Dbam31 is on a distinguished road
okay well here's my ideas:
1. DID you check your motor mounts yet?
2. DID you un-bolt the screw that holds down your brake lines on the upper fender well shock on the driver side?
3. Are all your radiator hoses on tight and clipped properly?
4. You might have pinched your fuel lines along the frame rails on the driver side.
DOUBLE CHECK everything, just did mine last sat. took 19 hours, but everythings perfect.
Old Jun 11, 2010 | 03:40 AM
rob44_90's Avatar
rob44_90 is on a distinguished road
Okay. I'll check everything out tomorrow. Where are the motor mounts located? Yes, I took off the screw that holds down the brake lines on the driver side. Radiator hoses look fine and no loss of antifreeze. Ill check the fuel lines tomorrow. I cleaned out the EGR today, but no luck. It just really sucks that it's doing this now. I just had it running better than new the day before I lifted it. Thanks
Old Jun 11, 2010 | 07:05 AM
richy97blazer's Avatar
richy97blazer is on a distinguished road
i had the same thing happen to mine right after i changed the plugs an wires ... so i went an messed with the distribitor cap a it stoped haveing the ruff idel an hasent done it again...
Old Jun 11, 2010 | 01:35 PM
rob44_90's Avatar
What did you do to the distributor cap? I've made sure every hose is secure on it.
Old Jun 13, 2010 | 01:39 PM
i would turn it off an move it around a lil crank it up... an it finaly stoped... an un hook a spark plug wire 1 by 1an put it back on just to make sure there all on good...
whitejimmy
Lifting Tech
22
Mar 8, 2010 02:50 PM
ComputerNerdBD
Feb 28, 2010 11:30 AM
volfan4
Nov 28, 2009 08:04 PM
midnightmekanik
Oct 8, 2009 08:32 PM
cide
Mar 23, 2009 10:57 AM
