2 inch rough country lift
Yeah, it says the recommended tire size is 30s on their page... But if you decide to get that 2 inch ifs lift, with a little fender trimming, I think you would be able to fit 31s on there. If you're comfortable shedding some of your blazers fender, 31s are definitely doable.
I have just finished installing a 2" body lift from Performance Accessories on my 1999 S10 Blazer...very easy! The only modifications were during reassembly of the rear bumper (had to trim a bit of the frame for a correct fit), everything else was provided in the kit (oil filter brackets...ground strap extensions...front/rear bumper brackets...fuel filler tube hose for extending to the filler access). The only issue I have is a higher idle rpm now (from 750 to 950 rpm)...I am sure it is a vacuum issue, but I have performed a very thorough inspection and am still a bit miffed...anybody else had this issue after installing a body lift?
That was my first thought, but turns out not to be the issue. I will continue the search for a leak. As far as exposing more of the frame, a quick power-wash followed by a can black rubberized sealant looks really good! Cannot wait for the Black Wheels and Yokohama's to get here!
