2 inch rough country lift
Old May 19, 2013 | 01:03 PM
01blazer16's Avatar
01blazer16 is on a distinguished road
Default 2 inch rough country lift
Will a 2 in rough country lift fit 31s on my 01 blazer 2wd???
Old May 20, 2013 | 05:10 AM
sickman420's Avatar
sickman420 is on a distinguished road
Old May 20, 2013 | 01:29 PM
tibby's Avatar
Default .
Yeah, it says the recommended tire size is 30s on their page... But if you decide to get that 2 inch ifs lift, with a little fender trimming, I think you would be able to fit 31s on there. If you're comfortable shedding some of your blazers fender, 31s are definitely doable.
Old May 20, 2013 | 08:02 PM
sickman420's Avatar
Get a body lift. They're low priced.
Old Jun 12, 2013 | 10:19 PM
stormyd's Avatar
stormyd is on a distinguished road
I have just finished installing a 2" body lift from Performance Accessories on my 1999 S10 Blazer...very easy! The only modifications were during reassembly of the rear bumper (had to trim a bit of the frame for a correct fit), everything else was provided in the kit (oil filter brackets...ground strap extensions...front/rear bumper brackets...fuel filler tube hose for extending to the filler access). The only issue I have is a higher idle rpm now (from 750 to 950 rpm)...I am sure it is a vacuum issue, but I have performed a very thorough inspection and am still a bit miffed...anybody else had this issue after installing a body lift?
Old Jun 13, 2013 | 09:23 AM
AndrewO1991's Avatar
AndrewO1991 is on a distinguished road
is your throttle cable pulling the throttle now that it's further away? My only protest to body lifts are that soooooo much of the frame is already exposed, it looks funny with more.
Old Jun 13, 2013 | 09:29 AM
stormyd's Avatar
That was my first thought, but turns out not to be the issue. I will continue the search for a leak. As far as exposing more of the frame, a quick power-wash followed by a can black rubberized sealant looks really good! Cannot wait for the Black Wheels and Yokohama's to get here!
tibby
Lifting Tech
54
Dec 29, 2015 11:13 PM
Dolanjohn1990
Lifting Tech
Aug 6, 2014 07:14 PM
BackwoodsBogger14
Lifting Tech
Mar 26, 2014 08:45 PM
priesman64
Lifting Tech
25
Apr 8, 2013 12:18 PM
abig84
Apr 6, 2011 08:00 PM
