2" shackles and ~2 tbar crank...
Old Aug 16, 2012 | 12:38 PM
Wisco Blazer's Avatar
Wisco Blazer will become famous soon enough
Default 2" shackles and ~2 tbar crank...
Was a PITA but i finally did it.
Before
After
Old Aug 16, 2012 | 03:57 PM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
Sweet man looks good, got any pictures of your cv angles? I have mine cranked with shackles looked sweet and wanted it higher so I added a body lift, once you start lifting it you can't stop haha.
Old Aug 17, 2012 | 11:59 AM
seanmurphy265's Avatar
seanmurphy265 is on a distinguished road
Did you have to remove the entire leaf spring to add the shackles? I have a set and the directions say to remove the entire leaf spring. I don't see you couldn't remove the rear only and bolt on the shackles.
Old Aug 17, 2012 | 01:28 PM
50lb_cat's Avatar
Can you post a pic of your cv angles? Usually going more then 1.5 inches on a tbar crank you ask for problems...
Old Aug 17, 2012 | 01:49 PM
I just removed the stock shackles and put the lifted ones in, had to use a big pry bar to pull the leaf springs down enough to put the bolt through. Found it easier to put the top bolt in and then the leaf srping bolt in. probably could've been easier if I let the shock go but didn't want to add more work.
Old Aug 18, 2012 | 04:01 PM
That's how I did mine, and it worked out just fine. I did the same thing with a 2" shackle and Tbar crank. I had already added the Rough Country add a leaf to help with sagging. I also replaced all four of my broken shocks with four rough country shocks. I have a 1992 4door 4wd and I like the stance much better now than before. All I need now is bigger tires!
bclhaezveyr
Lifting Tech
33
Feb 24, 2012 02:05 PM
BlazHerZR2
Lifting Tech
Nov 11, 2011 07:23 AM
sk8indigomoon247
Lifting Tech
Aug 19, 2009 10:45 AM
jdblazin
Lifting Tech
Nov 21, 2007 07:06 AM
jimmyboy
Tires and Wheels
Dec 4, 2006 09:46 PM
