2000 blazer lift help!!!!
yup, i already have the shackles and now i am just waiting on the wheels and tires. i am going with soft 8 16" with a 5" backspacing. and i am going with 265/75r16 cooper st.
I was told before that cranking to torsion bar to lift ur ride height created front end ware, or is that why u stated 1.5" max? If I purchased a 2" body kit plus the shackles and cranked the torsion bar 1.5", how much would the ride quality change? So with the 2" BL and 2" SL i should be able to run on 31 x 10.5's without needing to regear or trim right?
And the tires i mentioned before are 33 x 10.5's and are buried under a ton of snow.
ORIGINAL: B chevy99
yes, that is correct.
with the the 2"sl and 2"bl, u should be able to clear 32 with minner triming. 33 with more trimming. there are a few ppl running 33 with that kind of lift on here. depending on what size tire you are running, plus the lift you are adding, you will probably get 4" of total lift in the front.
36's with no trimming, its going to cost alote trust me
http://i496.photobucket.com/albums/r.../blazer001.jpg
COUNTRYBOY061488
Aug 28, 2008 07:54 PM
