33x12.50 15s
No you dont.
Do they make a 3 inch body lift for a 2000 zr2 blazer?
if so can someone post the link up
i fit 35 12.50s on a stock 85. just take a sawzall, hack away for a few hours, get some rims that make the rubber stick way the heck out and your all set. after a few months offroading it the body started to split cause it was a rotted truck so the tires had to rub and eventually put on 33s.
the guy i did buy the 33s from had them on his 89 s10 with only a 3inch body lift. he said it did rub but only offroad
mine with 35s
3inch body lift and 33s
but yeah to do it right without cutting anything, i straight axled the front of my 93, put the axle under the springs in the back with a 4inch block and im running 33s, they still rub under extreme circumstances
mine with 35s
i didnt have to take my tank out but i cut the old shackles out and torched the bolts went with new bushings and bolts
