4 door lift leaf springs
Old Jun 2, 2012 | 08:48 PM
tttlesabre's Avatar
tttlesabre is on a distinguished road
Default 4 door lift leaf springs
Does anyone make a 2 inch lift rear leaf spring for a 2000 4 door. I did not want to use an add a leaf because of the harsh ride they give. Any susgestions would help. If I need to use the aal then I will but I figured I would rather get lifted springs because I need new springs anyway. Thanks
Old Jun 2, 2012 | 10:03 PM
blaz's Avatar
blaz is on a distinguished road
I just added 2 long leaves to each spring pack on my 2 door. I was also concerned about a harsh ride. With the long 1/4" leaves I had no problems at all.
Old Jun 3, 2012 | 02:47 PM
rexmburns's Avatar
Super Moderator
Just get 2" lift shackles for the rear. Gives you some lift and won't change the ride at all in the rear. What are your plans for the front t-bar crank?
Old Jun 3, 2012 | 04:30 PM
tttlesabre's Avatar
The front is a ZR2 front frame clip. The zr2 springs hit. I am going to see if I can get the front modified by a spring company If I cannot find springs. The back needs to be the same height as the front. I am still working on it and will post pics when I am finished. I will post the entire process.
cory renner
Lifting Tech
Feb 5, 2013 05:46 PM
xJakeLIKEShisBLAZERx
Lifting Tech
Nov 9, 2011 04:21 PM
sandman6983
Lifting Tech
Jan 10, 2011 01:49 AM
S10Blazerdude
Lowering Tech
May 1, 2010 07:56 PM
lennyblazer
Jul 6, 2007 11:10 PM
