90 k5 lift questions
Old Feb 28, 2010 | 06:03 PM
K-BERTHABABY-5's Avatar
K-BERTHABABY-5 is on a distinguished road
Exclamation 90 k5 lift questions
i am gonna get a 4 inch skyjacker kit ..and it comes with leafs for the front and blocks for the back and it has all the hardware such as ubolts and bushings.......and 2 shocks ......besides the 2 other shocks is there andthing else i need like extended brake lines or anything steering?
if u have info and kan help then thanks..if not then thanks n e ways
Old Feb 28, 2010 | 08:17 PM
a_tack's Avatar
a_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud ofa_tack has much to be proud of
Skyjacker makes a good quality product. If you should need brake line extensions, skyjacker will include them with a NIB lift kit from the factory. Mainly because if they are needed and not provided, it is a huge liability issue and they don't want sued because someone used their kit and ran off a high wall because their brake lines were too short and came loose.
Old Feb 28, 2010 | 08:43 PM
I would stay away from lift blocks in the back if you can at all help it. I have never liked blocks. A shackle flip will pretty much get you the 4" in the back to match 4" springs in the front.
You may want to rebuild the front steering at the same time. That added lift and, assuming, larger tires is going to exaggerate any play in the steering.
Old Feb 28, 2010 | 10:01 PM
abig84's Avatar
yeah it should have came with some kinda lift steering arm with that much lift. though it is possible to use your exsisting arm your steering is going to really suck and under any kinda flex you will probably max it out and break a tie rod end.
raiders09
Lifting Tech
Jan 27, 2010 02:26 PM
brino1
Dec 16, 2009 04:17 PM
96BlazerGrrrl96
Nov 11, 2009 10:58 AM
vankuen
Sep 22, 2007 05:26 PM
joe134
Suspension Tech
Mar 14, 2006 11:02 PM
