95 S10 blazer 4wd 2dr lift available?
I'm looking for a 5-6" suspension lift for my 95 S10 2dr 4wd blazer. I can find ones that fit 4drs but I'm having trouble finding one compatible with 2drs. Does anyone know company that makes one? New here hope I'm following the rules thanks.
I would think you could use what they have for the 4dr for the front and then work out what you need for the back. Would not the springs and shackles be the same and all you need is a different rear drive shaft?
The front suspension is the same on the 2 doors...Idk about the rear springs, but I'm pretty sure rough country lifts are just an axle "flip" kit to make it Spring over axle. 2 door and 4 door both use the same rear axles, so that shouldn't make a difference either.
mdmccurr
Jul 19, 2024 08:27 AM
