95 S10 blazer 4wd 2dr lift available?
Old Feb 24, 2018 | 08:03 AM
John Grose's Avatar
John Grose is on a distinguished road
Default 95 S10 blazer 4wd 2dr lift available?
I'm looking for a 5-6" suspension lift for my 95 S10 2dr 4wd blazer. I can find ones that fit 4drs but I'm having trouble finding one compatible with 2drs. Does anyone know company that makes one? New here hope I'm following the rules thanks.
Old Feb 24, 2018 | 11:44 PM
Did you check Rough Country? There is also Super Lift. You might have to cobble together what you want to do.
Old Feb 25, 2018 | 10:58 AM
Lefet's Avatar
Lefet is on a distinguished road
I agree with Christine, I would ask specifically if it will fit. I want to do the same. 6" lift on my 94, 4 door.
Old Feb 25, 2018 | 11:24 AM
John Grose's Avatar
I've messaged rough country and they don't carry anything for a 2dr I was told super lift used to have one but I can't find a listing for it anywhere.
Old Feb 25, 2018 | 04:48 PM
What did RC say?
I would think you could use what they have for the 4dr for the front and then work out what you need for the back. Would not the springs and shackles be the same and all you need is a different rear drive shaft?
Old Feb 25, 2018 | 06:16 PM
chevyriders's Avatar
The front suspension is the same on the 2 doors...Idk about the rear springs, but I'm pretty sure rough country lifts are just an axle "flip" kit to make it Spring over axle. 2 door and 4 door both use the same rear axles, so that shouldn't make a difference either.
mdmccurr
Jul 19, 2024 08:27 AM
avengedblazer
Lifting Tech
Apr 7, 2010 10:43 PM
SmoyMoose
Mar 30, 2010 07:41 AM
hayfieldfarm
Engine & Internal
Jan 5, 2007 09:13 AM
cherryred4x4
Suspension Tech
19
Sep 8, 2006 08:08 PM
