Add a Leaf & RC Shackles
Old Apr 7, 2017 | 10:13 PM
TMM217's Avatar
TMM217 is on a distinguished road
Default Add a Leaf & RC Shackles
What size lift should I get in the rear with a 2" add a leaf and the Rough Country 2" lift kit shackles? Is it simple math and 4" in the rear?
Old Apr 8, 2017 | 10:55 PM
Not quite. With a 2" taller shackle, you get half that length in lift. Reason being, you're only moving one frame mounting pivot point of the spring away from the frame. So a 2" longer shackle will net you about 1" lift.
So you're realistically looking at a total of 3 inch lift if you combine the two.
Old Apr 9, 2017 | 09:10 AM
TMM217's Avatar
Ok so the Rough Country 2" lift only lifts the rear 1"?
Old Apr 9, 2017 | 10:19 AM
newguy's Avatar
If the holes are 4 inches farther apart than stock it will be 2 inch lift
Old Apr 9, 2017 | 02:30 PM
TMM217's Avatar
I cant remember if I ever compared the 2 shackles. Ill have to measure the RC shackles.
The reason for all of this is I did the RC lift and had an alignment done and the shop adjusted the torsion bars to get a good alignment and not a even ride height with the rear. As it sits now the front ride height is higher than the rear and Im trying to get it to even out with add a leafs in the rear. My luck the add a leafs will raise the rear too high.
Old Apr 9, 2017 | 05:21 PM
newguy's Avatar
Rather have the rear an inch higher
TylerAustin22
Apr 29, 2013 12:44 PM
SOB1999JIMMY
Lifting Tech
Jul 8, 2012 10:34 AM
PaulO2288
Apr 21, 2011 12:25 AM
litterbug
Lifting Tech
Mar 25, 2011 10:28 AM
jphayes921
Lifting Tech
Oct 24, 2007 02:54 AM
