can i fit 33's
Old Feb 23, 2014 | 08:34 PM
chevyboy_1986's Avatar
chevyboy_1986 is on a distinguished road
Red face can i fit 33's
i have a 97 blazer with a 3" suspension and a 2" body lift. can i fit 33x12.5x15 tires
Old Feb 24, 2014 | 09:18 AM
El_Beautor's Avatar
Sure but you won't be able to turn your wheels without rubbing. If you put those on you'd better expect to be cutting a lot of fender material off both the front and back wheel wells and you'll probably be rubbing the frame pretty good depending on your rims. If you scale back slightly to a 33x10.5x15 you should be able to fit it ok. There's several memebers on here running those with a similar lift setup. Look up Blaz in the members section. He's running a similar setup and he and Jamaroon did a great how-to.
Old Feb 24, 2014 | 07:07 PM
Default yeah i was afraid of that
http://www.ebay.com/itm/15-X-8-VISIO...INCH-19-.these are the rims im putting on. what do you think did i make the right choice.
Old Feb 24, 2014 | 07:27 PM
i am really wanting to use these tires my boss is giving them to me. cant beat free. i am a father of 3 and living on only my in come so you can imagine money is pretty tight. im stuck between a rock and a hard place now i bought the lift kit and rims and if im reading this right i am not going to like what im going to have to do just to use these tires i understand the front having to be trimmed up but the back i dont understand. im new at lifted 4x4's so any help will be real big help
Old Feb 24, 2014 | 07:36 PM
Jamaroon's Avatar
You're going to have to trim a lot to get 33's to work with those wheels.
The wheels will stick out 3.25" further than stock, plus the extra width of the tire above that. ~1.5" would be close to flush with the fenders.
Here's the thread EB was talking about.
https://blazerforum.com/forum/tires-...er-pics-71189/
Old Feb 25, 2014 | 09:11 AM
El_Beautor's Avatar
I understand your situation. I'm in the exact same boat with 3 kids and a single income. It's one of the reasons gettting things done on my truck takes a really long time to complete.
Regarding the back needing trimming just remember that these trucks were designed for 28" tires. The wheel wells are not big enough to fit a 33" tire without opening them up a bit. The front is way more restrictive, especially at the back of the wheel well. The rear is a little bigger and only has to fit vertical travel of the tire, but it's still not big enough to tuck a 33" tire. I haven't modified my rear wheel wells but it's very close to rubbing when my suspension is flexed off-road with my 32" tires. I really need to do some trimming but it's going to have to wait for warmer weather since I don't have a garage.
Old Mar 25, 2014 | 06:23 PM
okiedoak20's Avatar
Chevyboy....come on dude. And drop $2200 on a 5-6"
BDS or Superlift suspension kit....thos 33" will look real purty
Then...
kuojo
Oct 14, 2011 12:01 AM
wlorton
Tires and Wheels
Aug 23, 2009 06:12 PM
ivannj
Dec 22, 2005 03:28 PM
Blaize70
Tires and Wheels
Apr 6, 2005 02:00 AM
