Hey, new here. Have a noob question
Old Sep 12, 2011 | 11:10 PM
96jimmy_NB's Avatar
96jimmy_NB is on a distinguished road
Default Hey, new here. Have a noob question
I've been stalking the lift threads lately reading up on the different kinds of lifts and I started to wonder which kind of lift would be better for a noob blazer/jimmy owner like myself? I'm not totally sure what kind of lift I should do. Whether it be a torsion bar crank with rear shackles/add a leafs or a body lift. I would think they would do the same job and since they're both cheap I'm not really sure which would be better. I'm looking to get 31"s in the future so I'm thinking a 2-3" with minor trimming would work. I'm just stuck on which lift would be better in the long run.
Old Sep 12, 2011 | 11:18 PM
warthogdriver's Avatar
i would say from my own exp that you can get away with 1.5" torsion crank and 2" rear shackles for 31's no problem. i did that for awhile while i saved for my suspension lift.the only pain is going to be getting the rear shackles apart.
you can then see if you want to add to that with a body lift.
its all personal taste and what your goals are in the long run.
Old Sep 12, 2011 | 11:22 PM
xgiovannix12's Avatar
I did a 1.5 inch tbar crank and 2inch shackle install i had to grind my fender flares a bit but it worked out great
im running 31/10.5/15s all terrains
janet7
May 24, 2011 02:16 PM
driftingrz
Feb 17, 2010 09:12 PM
trad444
May 9, 2009 09:01 PM
heathcliff1962
Dec 26, 2008 08:57 PM
Private_Ops
Jan 24, 2008 07:15 PM
