how much does a ZR2 have? tire/space = me question
the "ride" in not great as the shocks are worn and im sure the t-bars are to but its so close without any push down that i dont think its the t bars being weak as much as the tires. my plan is to do a 2 or maybe 3 inch body lift and that would take care of the problem right? also will be putting my 1.25 inch spacers on the front after. with a body lift i should be good though right?
anyone have any suggestions for new shocks for my blazer with the t bars maxxed out, they would help the ride and rubbing to wouldnt they?
no i will be putting my 2inch rear spacers on and my 1.25 for the front just didnt mention the rear. and because i want them to stick out more.
you do realize two problems that you're making for yourself.
1. by using spacers, and putting the wheels farther out, you will be increasing the amount of contact that will occur between your tires and fenders.
2. by using spacers, you'll be increasing the chance of stud breakage on your axles/hubs. even if you use the longer and stronger racing approved studs, there is still the added strain of the greater distance that the studs have to hold the wheels on.
question? why not just buy wheels that have the right amount of off-set that you want? i know this requires spending money,and that you already have these wheels, but the added benifit of buying the correct parts, gives you the knowledge that your build is going to be safe.
i have ran wheel spacers for almost a year without a single problem whatso ever. so i will be using them again soon. i think if i do a 2 or 3inch body lift and the spacers im hopping everything will be okay, i hope haha
i've gotta ask, when you say "spacers", do you mean adapters in the same bolt pattern, or are you using longer studs with a 2" slug between the hub and rim?
i believe you will still have rubbing issues with the offset you have with your rims.... even with a body lift.
unfortunately, i think it will only get worse up front no matter what you do if you put them further out with spacers.
i see no issue with spacers as far as safety goes, as long as you run hub centric spacers. i have some on the back.
i have hub centric ones also. i will see what happens after the body lift.
blazinUP
Tires and Wheels
05-14-2010 08:06 PM
