leveling kit help
#21
any 2" lift shackles will get the job done. check out ebay if you cant find any locally.
#22
Shackles are what link the rear leaf springs to the frame, getting longer ones will lift the rear of the truck.
#23
#24
Here are a few sources for shackles...
http://www.tellico4x4.com/index.php/...4281_4742_3361
http://www.rockymountainsusp.com/GM_S10_4wd.htm
#25
ok thank you all how many do i need to buy and so its 2in shackles for 1.5in lift?
#26
youll need 2 shackles, one for each side.
#27
ok ty
wouldnt i need to get 1.5in shackles for 1.5in lift so that it is level in the front and back?
#28
No, your really not going to be able to tell the difference with 2in shackles and 1.5 tbar.
#29
I cranked my t-bars and did not add shackles in the rear b/c of the extra weight of the bumper, but I only have 30 in tires. I can tell you it didn't rub AT ALL on the trails in CO, even on the switchbacks and hairpins. I was worried at first, but lemme tell you, crank those bastards and get the alignment!
#30
i cranked my tbars also got the shackles at autozone and welded a piece of square tubing in them they work fine i'm running 31x10.50s on a 2" lift had to trim the inner fender well a little. going to get alignment tomorrow.
