lift help for a noob =/
Old Apr 14, 2009 | 02:57 PM
Shotgunn99's Avatar
Shotgunn99 is on a distinguished road
Default lift help for a noob =/
Hello there! Ive had my 99 4dr 4wd blazer for three years now, and I want to lift it.
I would like to run a 2-3in lift all around with 31in a/t tires.
Any recomendations on going about doing this?
My plan is to get new torsion keys for the front, 2in shackles and add a leafs in the rear.
good or bad?
Thanks.
Old Apr 14, 2009 | 03:02 PM
oisinirish's Avatar
have you tried running a search? There's boat loads of ideas in here. As well as discussions on what will/will not work and why.
Old Apr 14, 2009 | 03:14 PM
Shotgunn99's Avatar
yes I have.
I've been reading on and off on these forums for a year and really have HardxCore researching this past week. I just would like to hear some opinions from experienced "lifters" before I do this.
Old Apr 14, 2009 | 11:40 PM
okvortec's Avatar
I believe a non ZR2 blazer needs 2" lift to clear 31's, however you can put them on with the truck stock but they WILL rub when you turn...
Cheapest way to get the lift you need is a body lift, they sell for a few hundred bucks and you can most likely install yourself with a buddy for extra hands!
Old Apr 15, 2009 | 05:58 AM
nj4x4blaze's Avatar
This is something that has been answered many times in the threads below. You can do a 2" body lift and fit 31's. The body lift isn't hard to install and with a few friends you can have it done within a few hours. As for shackles and a t-bar lift, multiple members have gone down this route. Just remember that the maximum lift you are going to get from your stock t-bars is 1.5", anything higher than that that will result in wear and tear on your front end components like ball joints, cv axles, pitman arm, idler arm and ect. If you plan on getting new t-bars, I suggest finding a set of ZR2 t-bars. PM Orangesonoma, he has ZR2 t-bars on his blazer.
Old Apr 19, 2009 | 08:51 PM
Lifted02Blazer's Avatar
Lifted02Blazer is on a distinguished road
I was wondeirng if you could order a stock zr2 lift from the delaer and put it on my 02 s10 blazer? i have 2 inch body but was wanting a lil more? any help appreciated
Old Apr 20, 2009 | 08:30 PM
a 2 inch lift will clear 31s but they rub whn u turn and when u hit bumps and turning thy are very close to the rear and front wheel wells
muse475
Lifting Tech
Dec 27, 2009 10:29 AM
GetNice24
Lifting Tech
Dec 22, 2009 04:33 PM
88redblaze
Jun 19, 2008 08:25 PM
BlazerINtheWork
Lifting Tech
Nov 24, 2007 12:05 PM
Skywurz
Dec 5, 2006 10:26 AM
