Lifting 98 4dr 4x4
Lifting 98 4dr 4x4
Okay, So I've got a 98 Blazer 4x4. I'm thinking about getting GT Grabber AT2's with Pro Comp's Series 52 Flat Black. I plan on cranking the Torsion bars, and getting 2" shackles. If I do both of those, Can I add a 2" body lift?? How would that look? Can anyone can help me out with tire and rim sizes? Also how about the rubbing issues?
Thanks! What is 2" RC lift? And what did you do with your front bumber?? I want mine like that.
RC is Rough Country. It's a brand name. If I'm not mistaken he just removed his airdam on his bumper (cut it off)?
Thanks Sisk, Yeah. That what it appears like. I've got cracks in mine, So I think i'm gonna cut it off too. haha
I removed the lower valence when it was stock because it looked better that way IMO.
Ah I see. How'd you do it? Just cut it? With what?
Oh, and what is the difference between a 97 and a 98 2" body lift? It makes a huge difference in the budget!
if you check body lifts on summit site it will give you run down on dif. ....mostly brackets and such.
The valence has small bolts that run the length of it on the inside you have to take out.
