Lifting my 2000 2wd blazer
Old Apr 16, 2010 | 02:24 PM
WhiteKnight2000's Avatar
WhiteKnight2000 is on a distinguished road
Question Lifting my 2000 2wd blazer
I sent my 2000 2WD Chevy Blazer S10 to Off Road Concepts to get lifted. As far as a suspension lift kit all they said they had was a 2inch lift by Rough Country. Well I just got my blazer back and they said they were able to get about 3 1/2 inches out of it which is cool, but now the smooth ride i had is completely gone. It feels smooth when you don't hit any bumps, but the second you do my truck is bouncing ALL over the place. Is this normal? a couple of my friends said no.
Old Apr 16, 2010 | 02:29 PM
*Moved to Lifting Tech* - The Forum Help & Suggestions Center is for forum related issues. Technical questions have other sections.
What did they do to lift it?
Old Apr 16, 2010 | 02:42 PM
okvortec's Avatar
Also, if you dont mind me askin, how much $$ was the grand total?
Old Apr 16, 2010 | 02:49 PM
nj4x4blaze's Avatar
Did they change out the springs?
Old Apr 17, 2010 | 11:28 AM
ScottyBoy98's Avatar
ScottyBoy98 is on a distinguished road
even though you got 3.5 inches of lift it sounds like they put some 3 inch lift coils up front,once they settle it may drop a little bit...but anyone who's ever had 3inch coils on a 2wd s10 or blazer will tell you they ride like crap, especially over bumps since they are so stiff...hope you didnt spend too much on it, 3 inch lift spindles would have given you the same lift and not affected your ride quality at all, but only if you were willing to downgrade to the s10 pick up style brakes.
Old Apr 22, 2010 | 04:43 AM
yeah dude especially on speed bumps thats when they are the worst. I spent 750 on the lift with parts and labor. I was looking into doing a suspension lift and a body lift before i put bigger tires so i could go with the biggest option. Will the coils being so stiff affect the engine over a long period of time? It feels awful and I have to drive really slow.
Old Apr 23, 2010 | 12:18 PM
well if you plan on lifting it more in the front you only have 2 options left after the coils...you can get 3 inch lift spindles (about 270 shipped off ebay) and put on s10 pick up brakes or do a 2 inch body lift...or both if you want to run 33's, then for the rear you'd have do a SOA for about 4.5 inches then you could add blocks or shackles for an extra 2 inches...and about the rough ride, do you know what kind of shocks they put on your blazer? maybe you could upgrade...and as far as the stiff ride affecting the engine it should be fine but it depends on how drive you might break a motor mount
Old Apr 25, 2010 | 11:03 AM
twistedsmily's Avatar
twistedsmily is on a distinguished road
have you looked into the LT kit from airbagit.com the problem is theres 3" of lift on stock control arms, or at least thats my thoughts. and from what i read the short arm kit is just stock size tube C arms.
Old May 14, 2010 | 04:28 AM
scottidog2000's Avatar
scottidog2000 is on a distinguished road
what specific break parts need to be replaced from the s10 to the blazer for the spindle lift 3.5'' spindle lift to work on a 2000 2wd blazer?
01blazer16
Lifting Tech
Aug 13, 2013 10:00 AM
ilovedonuts13
Lifting Tech
Apr 1, 2011 11:04 PM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
Blazin01
Lifting Tech
Jan 19, 2009 01:43 AM
pfcmooney
Nov 8, 2007 04:15 PM
