Need Help and Advice on Shackle lift and more
Old 02-15-2010, 10:17 PM
Quik's Avatar
Quik is on a distinguished road
Originally Posted by Rottidog
2" shackle adding stress? maybe im misreading this but a 2" shackle does nothing more than raise the body of the rear 2", possibly new shocks, gas filler tube addition, not so sure about the filler tube, have to look
"also in the front you won't be able to compensate for that inch. the t-bars can only go so far before you wear like crazy" <--- agreed, some say they've had 2" t bar cranks & no issues, personally i wouldn't want to go that far & just for that reason
as for the nose dive - i've seen many blazers that seem to be squating/rear lower than front, mine included
yeah 3" in the rear & only 1.5" in the front would be a bit much unless you have tired springs up front or in the rear
you wont have to lenghten the filler neck since the part your changing isnt effecting the filler neck. its only changing the axle to frame distance not frame to body distance
alot of ppl do say dont go past 1.5" without wear. ive put 32k on my blazer with my TB cranked no issues however i may just be a lucky one. since i had sagging leafs in rear i went with little longer then standard lenght shackles to help compensate. I currently run a true 32" tire on 2"bl shackles and tb crank
Old 02-16-2010, 09:36 PM
BlazerGuy2001's Avatar
So i went out to measure the distance from the top of the rim to the bottom of the fender and figured out that the front is sitting at 13.5" and the back at 12", so i think the 3" shackles would be best because they would bring both to 15" with a 1.5" TBar crank, what do you all think?
Old 02-20-2010, 03:54 PM
Is there a torque spec on the shackle bolts
Old 02-20-2010, 03:55 PM
Spectreblazer's Avatar
Banned
Spectreblazer is on a distinguished road
yup
torque spec: tight.
lol
p8ntmods
Lifting Tech
07-25-2014 08:58 PM
FIVEHORSE
Lifting Tech
03-17-2013 01:46 AM
Tommyboy8299
Lifting Tech
01-26-2013 10:39 AM
wills-07
Lifting Tech
12-19-2010 07:09 PM
Quick Reply: Need Help and Advice on Shackle lift and more
