plans for my blazer
Old Jun 30, 2012 | 09:52 PM
Kudjy65's Avatar
Kudjy65 is on a distinguished road
Default plans for my blazer
hi im thinking about lifting my 2000 blazer i want to put the 2.5in rough country lift nd a body lift nd i also want to run 31 or 32in tires does any one know if i am going to run into any major problems or if this setup should work ok
Old Jun 30, 2012 | 11:37 PM
warthogdriver's Avatar
those two lifts combined should be enough for 31's
all i did for mine when i was at 31 stage was a body lift and torsion/shackle lift.
if your not to familiar with body lifts look for the
performance accessories pdf install manual and read it prior to jumping in.
also be sure to shoot all the body mount points with pb blaster or wd40 at least a week prior to body lift. those bolts can be a p.i.t.a.
if you have a four door there are 12 body mount points...two above axle are usually missed when looking for body mount points.
hope that helps ya out.
Old Jul 1, 2012 | 11:38 AM
tibby's Avatar
Default .
You can run 32s with the 2.5 inch ifs and 2 inch body lift with some trimming. I had to trim to make 31s fit with just my 2 inch body lift.
travisrussell88
Jun 13, 2011 09:43 PM
CraigSnedeker
The Chop Shop
Nov 4, 2010 04:09 PM
blazendizz
Mar 11, 2010 04:57 PM
dougg01
Jan 29, 2010 09:52 AM
