Rear shackle, but what to do up front?
Old Sep 11, 2011 | 01:09 PM
HigherPower's Avatar
HigherPower is an unknown quantity at this point
Default Rear shackle, but what to do up front?
What would you do up front in the case of raising up the front past what a 2" tbar lift would possibly do? I know you could do a tbar lift but at what price would you pay for wear and tear? Whats the alternate to make up what a 3" shackle in the rear would do without expense and diffuculty (if you notice my location, even milk is like gold and mechanics are worth platinum...)
I am thinking of a tbar and a corresponding shackle @ 1.5/2" but if I can get a bit more like 3" then what would I do to the front?
Thanks
Old Sep 11, 2011 | 01:33 PM
mdehoogh's Avatar
Thanks
There's nothing really. At least, nothing that's cheap and simple. The stock control arms and axles can only handle about 1.5-2.5" (doesn't matter if it's new tbar keys or just a regular tbar crank). The only way to get more is to reposition the entire axle down. There are kits that come with all the brackets needed but they're all a 5" or 6" lift and cost $1000+ unless you can find a used one somewhere.
My suggestion would be to stick with 2" shackles to keep it level and then use a body lift to raise the whole truck up
Old Sep 11, 2011 | 02:08 PM
xgiovannix12's Avatar
I agree 1.5 inch tbar crank 2 inch shackle install then a decent body lift
Old Sep 12, 2011 | 01:30 AM
Thats what I was afraid of...I really don't want to do a body lift, at least right off I will stick to the Tbar/shackle lift for now. I put 30x9.5's on stock rims and they rub a little (not under normal driving though) so I'm hoping the 2" will give me the clearance I need so I can go off road and not have it rubbing as bad.
I will post the series of pics I have for the build. The front end was rebuilt after an accident and then once I got into it this summer I was waiting on parts to be shipped up here to the middle of no where and found my self fixing and restoring other things.
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
KNOFF1987
Aug 25, 2011 04:10 PM
DDBlazer4x4
Feb 18, 2011 11:38 PM
jason1978
Nov 10, 2009 01:02 AM
jeffreys25
Mar 16, 2009 12:10 AM
