Rough country 2.5"
Old Aug 16, 2014 | 12:16 AM
Dolanjohn1990's Avatar
Dolanjohn1990 is on a distinguished road
I used it to get the adjustment block in but then i was able to get the bolt in after removing the tool. The key was exactly the same size as the original ones.
Old Aug 16, 2014 | 10:17 AM
Jamaroon's Avatar
yeah the key is the same size, just indexed a little differently.
I'm running out of ideas, how far in is the bolt? Are you sure the weight is being supported by the torsion bars? It's not being supported by the bump stops?
Old Aug 17, 2014 | 02:59 PM
I know its being held by torsion bars because i never put the bump stops in. Forgot them. I dont even know how i would fix it if they weren't being supported by the torsion bars. The bolts can be taken all the way up with minimal adjustment
Old Aug 17, 2014 | 07:52 PM
Jamaroon's Avatar
Without seeing it in person I don't know what else to suggest. Maybe you should take a bunch of pictures of everything and post them up.
The adjuster bolt, the torsion bar in the control are, the upper and lower control arms etc, you never know. Someone might see something.
Old Aug 18, 2014 | 10:29 AM
I was finally able to get it cranked to 22.5" on one side and just under that on the passenger. How far up can i run the adjustment bolts? I havent maxed them out yet but dont want to if it would be unsafe/bad for my car. Ill post some pics when I get home.
Old Aug 18, 2014 | 11:05 AM
Jamaroon's Avatar
I'd leave them where you have them, people have had problems running at the full 2.5" lift. I think you'll have less problems with stuff wearing out or breaking if you leave it where it is.
Old Aug 18, 2014 | 11:22 AM
My only issue is I'm afraid if i dont run the full 2.5 I'll never get my 31s on.
Old Aug 18, 2014 | 04:03 PM
Jamaroon's Avatar
31's generally fit with just the body lift, I think you should be good.
Old Aug 18, 2014 | 06:52 PM
Yeah but my car came factory with 205s
Old Aug 18, 2014 | 07:24 PM
newguy's Avatar
2.5 plus 2 inch Body lift. 31x10.5 15
