Rough country?
Old Jan 24, 2019 | 12:05 PM
Originally Posted by carlosblazer
Do you have any additional problems assuming that you donīt drop the diff? considering itīs a 2,5" lift, maybe your differential is working on a critical angle, considering that the recomended lift doing the t-bar crank is 1" to 1,5".
Is this question for me? If so I can't say I've had any other issues although I'd recommend to anyone doing a T-bar crank lift that with all of the suspension work to be done on the front, it is a good time also to perform preventive maintenance service on the CV joints. I was a bit intimidated by them at first but actually it was not hard to disassemble the inner ones and replace the boots with new neoprene ones that are more flexible and refill them with fresh grease. After 15-20 years, it is worth doing to keep the joints in good working order if your axles still seem to be in good shape otherwise.
Old Jan 24, 2019 | 02:24 PM
cleburne red's Avatar
What size lift did you get, OP? I have the rough country 6 inch lift on mine. It drops the diff down, but the.cv angle still isn't flat by any means.
While we're on the topic, are there any heavy duty, high angle cvs available for our trucks?
shadow03
14
Jul 23, 2020 07:44 PM
Ian Seals
29
Apr 20, 2019 05:14 PM
blazer37
May 4, 2011 03:59 AM
extreme
Lifting Tech
28
Mar 2, 2010 08:20 PM
jaredi1989
May 31, 2008 08:08 PM
