rubbing opinions
Old Jan 13, 2008 | 01:10 PM
aced411's Avatar
aced411 is an unknown quantity at this point
Default rubbing opinions
Hi,
My new wheel/tire combo rubs when the suspension is compressed on a turn. I'm running LT255 x 70 x 16" (255 is about 30") on 2wd rims. The front stick out a little as expected. I have a 2" body lift scheduled for this coming week. The guy at the shop told me it would help over the phone but I'm sure they want the business regardless. Do you guys think the 2" body lift will help reduce or eliminate the rubbing?
Old Jan 13, 2008 | 01:18 PM
TripleBlackBlazer's Avatar
Default RE: rubbing opinions
Are you rubbing the inner fenders or against the frame/swaybars?
Old Jan 13, 2008 | 03:21 PM
aced411's Avatar
Actually it's hard for me to tell. I tried cranking the wheel all the way and pushing down on the front of the truck. All I can see is the bottom edge of the fender is pretty close....but still it's kind of guess work. I wouldn't think it would hit the inside given the wheels are further out than stock
Old Jan 13, 2008 | 07:29 PM
myronhntr80's Avatar
myronhntr80 is an unknown quantity at this point
you should be able to see a spot where they are rubbing the dirt off of the inner fender or the frame. I just put 31's on my 93 and they rub on the rear of the front drivers side inner fender and on the frame on the drivers side. There is a nice shiny spot where it has been rubbing.
Old Jan 14, 2008 | 06:11 AM
nj4x4blaze's Avatar
When you do your body lift it should eliminate your rubbing problem. The problem you are having is that you are at stock height with rims that stick out farther than stock so when you turn the wheel they rub on your fenders. With a small suspension lift will take car of that problem. My boy had the same problem with his 2dr blazer and after the 2" body lift the rubbing was gone.
Old Jan 14, 2008 | 09:07 AM
aced411's Avatar
Cool!
Old Jan 14, 2008 | 04:42 PM
willjones's Avatar
My friend was haveing the same problem with his 2 dr. All we did was a t bar crank in the front about 1 inch and he had no rubbing. So the body lift will definately take care of it.
Old Jan 15, 2008 | 02:40 AM
aced411's Avatar
That's good to hear b/c I'm not going to mess with the t-bar. I'd go back to smaller tires before I'd do that.
xgiovannix12
Apr 9, 2013 10:58 AM
breakyadown89
Nov 9, 2009 08:26 PM
Millertime21
Suspension Tech
26
Aug 19, 2007 12:16 PM
GW
Engine & Internal
Jan 28, 2007 03:21 AM
DrkJrny
Jan 17, 2007 10:12 PM
