Safe Lifting?
Old Aug 4, 2008 | 06:28 AM
basketballmail2's Avatar
basketballmail2 is an unknown quantity at this point
Default Safe Lifting?
Is there a safe way to get a 2-3 inch lift without causing premature ware to any components? I'm looking for all options, suspension or body lift wise.
Thanks
Old Aug 4, 2008 | 06:43 AM
nj4x4blaze's Avatar
Default RE: Safe Lifting?
You can get either a 2" body lift or 3" body lift.
Old Aug 4, 2008 | 06:51 AM
doesn't that put premature ware on CV and balljoints? at least that is what I've been understanding when reading about the lifting.
Old Aug 4, 2008 | 06:59 AM
Body lifts have nothing to do with the suspension.
Old Aug 4, 2008 | 08:15 AM
gotcha, I read to much of everything I think got me totally confused So basically you just lift the body higher then the frame is that correct? How does this affect if you have a brushguard mounted or the trailer hitch setup?
Old Aug 4, 2008 | 09:28 AM
WolfPack's Avatar
Check out my thread on my BL install...I've got a pic of the hitch explaining the issues.
Basically if you have a class 3 hitch, it won't work with the kit bumper brackets, but a class 2 will. Class 2 hitches only attach with 2 bolts on each side, class 3 uses 4 bolts. I'm still working out the best solution to get my class 3 hitch back on..
As for the brush guard, it depends how the guard mounts. My Hunter brush guard attaches to the bumper brackets, so it was just a matter of using a washer or two to space all the brackets (3 of them) properly. No problem at all
Old Aug 4, 2008 | 11:15 AM
I think I'm gonna wait till someone figures out the hitch issue in that case as I have a class 3 hitch, and don't wanne loos it cause of my go rihno step I have in the back But sounds good that it isn't all that hard and especially doesn't break anything.
Old Aug 4, 2008 | 10:03 PM
WolfPack's Avatar
Ive unfortunately let the hitch issue fall out of mind for the time being...had other repairs to do on the blazer. I'm planning on taking it to a welding shop and just getting the kit bracket cut and welded onto the hitch. Then I maintain the integrity of the hitch, and support the bumper!
sh1520
Nov 27, 2009 03:30 PM
mhollis
Tires and Wheels
Jul 26, 2009 08:41 AM
Inferno
May 5, 2007 08:03 PM
scottyk
Apr 6, 2007 08:52 AM
XBlazer01
Sep 12, 2006 12:29 PM
