sas question
Old Mar 30, 2013 | 01:29 PM
bdemutis's Avatar
bdemutis is on a distinguished road
Default sas question
I was wondering if I do the dana30 swap do I need to also swap my back axle I found a front for only 100.
Old Mar 30, 2013 | 02:01 PM
duxtoyz's Avatar
duxtoyz is on a distinguished road
yes, different bolt pattern. ul need to go to a ford 8.8 or something with a 5 on 4.5 bolt pattern. your blazer is a 5 on 4.75 bolt pattern. or u can get wheel adapters that bolt onto your drums but then u have to find wheels to fit. or u can just put the dana30 in and have 2 different wheels.....lol
Old Mar 30, 2013 | 03:09 PM
tibby's Avatar
Default .
Buy Crager soft 8's in two different lug patterns! Truck yeah!
Old Mar 30, 2013 | 04:54 PM
Jamaroon's Avatar
You can also make S10 wheel bearings work on the D30 axle to keep the 5x4.75 bolt pattern and ABS
Old Mar 30, 2013 | 06:15 PM
bdemutis's Avatar
Well I was just wondering if u could get a axle with same bolt patterns so I don't need to swap the rear every SAS swap I seen they swap the rear I'm just trying to spend less on it.
Old Mar 30, 2013 | 06:21 PM
bdemutis's Avatar
So what axle would have the same lug patterns unless I mix match for awhile.
Old Mar 30, 2013 | 10:45 PM
Jamaroon's Avatar
there are no axles with the blazer bolt pattern, the only options are wheel adapters or using the s10 unit bearings
Old Mar 30, 2013 | 11:11 PM
bdemutis's Avatar
Alright I'll look into that don't feel like dropping more money into it doing the rear if there is no need to. I want to try and do it the cheapest I can. Also has any one made the font drop bracket bolt on and then also welded after bolting it on to make it more sturdy?
Old Mar 30, 2013 | 11:30 PM
bdemutis's Avatar
This was just a thought from the looks yes I'll be able to get bigger tires but my axle will still be down low might raise it a little. I can't really see a gain in it I got stuck on my axle the last time because I sunk in clay so I can't see the SAS helping, Thanks for all the replies might just get a body lift then late on just get a older truck already with a solid axle.
okiedoak20
18
Feb 26, 2012 10:36 PM
jaked up
Lifting Tech
15
Feb 1, 2012 11:03 PM
dimone545
Suspension Tech
14
Jan 28, 2012 01:45 PM
oldsbravada2000
Lifting Tech
Dec 14, 2011 10:53 AM
banks
Suspension Tech
Mar 12, 2010 10:34 AM
