Searching for a lift kit
Old Jun 13, 2009 | 03:38 PM
  #21
NVANZEE's Avatar
not sure what the clearance difference it between 2wd and 4wd but you will need to do a little trimming either way to fit 31s
Old Jun 13, 2009 | 03:43 PM
  #22
mikeinwi's Avatar
mikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud ofmikeinwi has much to be proud of
if he had a 4wd with 2" of lift he shouldnt have to do any trimming for 31's, depending on the backspacing of the rims and if his front end is sagging or not.
Old Jun 13, 2009 | 03:44 PM
  #23
blazerguy22's Avatar
thanks guys now if i could just figure out my damn fog lights id be happy
Old Jun 13, 2009 | 03:52 PM
  #24
NVANZEE's Avatar
what size fuse are you using? Where do the wires run? What do the wires hook to?
Old Jun 13, 2009 | 03:54 PM
  #25
its a15 amp system so im running a 20 amp fuse the wires run to a switch under the dash and thru a hole in the firewall to the battery and to the lights the hole has a rubber grommet around it so it wont cut the wires the wires dont look cut but for some stupid reason the ****in thing still keeps blowing out
Jkrumm
Lifting Tech
Feb 17, 2011 04:35 PM
project 99
Dec 7, 2010 07:58 PM
ericthughes
Lifting Tech
Oct 13, 2010 10:56 PM
mrsuenos
Apr 21, 2007 04:27 AM
ceanern
Jul 6, 2006 08:33 PM
