shackle help!!
Old Sep 28, 2009 | 02:53 PM
nyzr21019's Avatar
nyzr21019 is on a distinguished road
Default shackle help!!
i bought 2 inch lift shackles for my zr2, will i have to crank the t-bar to level it out or will the rear end be higher if i dont?? i dont know what to do? also is cranking the tbar easy? do i need to buy anything to crank the tbar?
Old Sep 28, 2009 | 02:58 PM
Blazn1's Avatar
Blazn1 is an unknown quantity at this point
I don't have a zr2 but if you go up 2" in the back then you have to go up in the front too. cranking the bars is easy as marking the start point on the bolt and using a 18mm wrench, or your tire iron to turn it. There is a sticky post on how too with pics under lifting tech. Real easy to follow....
Old Sep 28, 2009 | 05:30 PM
AJBert's Avatar
I wouldn't worry about whether you need to crank your tbars until after you install the shackles. My guess is you've got the ever present saggy *** syndrome going on already with your ZR2.
When I installed my 2" shackles it brought the rear end up to just about what it was when new. There was a slight bit of rake to it but looked good. I didn't crank my tbars until the body lift and 33's.
Old Sep 29, 2009 | 08:59 PM
nyzr21019's Avatar
yea i got the sagging rear end thats why i got them
FIVEHORSE
Lifting Tech
Mar 17, 2013 01:46 AM
shawncullen
Nov 30, 2010 12:00 AM
BlazerGuy2001
Lifting Tech
13
Feb 20, 2010 03:55 PM
95blazerlt
Lifting Tech
Feb 14, 2010 01:47 PM
warthogdriver
Lifting Tech
18
Sep 6, 2009 08:39 PM
