T bar Alligment Issues
Old Nov 9, 2009 | 03:23 PM
Brianator99's Avatar
Brianator99 is an unknown quantity at this point
Default T bar Alligment Issues
Alright So I cranked my t bars an 1 1/4" about 2 months ago. I just now today got around to getting an alignment which is okay cause I dont drive it much. My tires were wearing evenly and it was driving fine. I took it to a tire shop and had an alignment and they cranked the keys back down to stock ride height. I have 1.5" shackles and the rake was really bad. I have the computerized printoff sheet and all that if anyones curious. Not sure what I should do. Im probably going to crank it an inch and froget about it. I have brand new lowers and I pretty much olny drive it in the late fall, winter, and spring putting maybe 6k on it. Your 2 cents would be appreciated. Thanks, Brian
Old Dec 9, 2009 | 08:36 PM
custom01blazer's Avatar
custom01blazer is on a distinguished road
in my oppinion t-bar crank just causes more problems then what it its worth un less you customize front diff lowering brackets.
Old Dec 9, 2009 | 08:56 PM
ABN31B's Avatar
t-bar +1.25" and got an alignment. i have the same print off. my alignment was off by a BUNCH... but i also totaled a crx with my d side front tire so.... it might factor in. IMO as long as you dont go over 2" over stock, you should be ok. 1.5 = should be fine. 1" no change.
there is always the guy that cranks his t bars +4 and has no problems, and the next guy goes up .75 on one side to fix sag and blows out a cv... do what you like
Old Dec 9, 2009 | 09:23 PM
So far its been 1 inch of crank and like I said they alligned me by cranking me back down and I went back up and even tire wear.
Old Dec 10, 2009 | 07:01 PM
when i adjusted my t-bars i started chewing up cv axels so i put them back down to where the axels dont pop anymore so im asuming there where they should be from stock position.
Old Dec 10, 2009 | 10:23 PM
How would one know the cvs are chewing up? I keep reading about the boot poping off or the grease comming out.
Old Dec 11, 2009 | 06:00 PM
I chedked my cvs today and they had grease. am I doomed or is that normal? Its only cranked an inch.
Old Dec 11, 2009 | 08:33 PM
Green grease = blown CV boot. You can try to replace the boot if it just recently started leaking, but if the joint has run dry, you have likely ruined it.
Old Dec 14, 2009 | 09:43 AM
your not doomed but if the boot is still on i definately drop the t-bars back down. you still might want to replace the axel depending on how long it has been leaking. they usually run 40-50 bucks depending whether you go with a new or reman axel. but in my opinion drop the t-bars back down or you will go through the same thing i did axel after axel. you learn how to do axels really quick when you do it numerous times.
sparty992
Jan 23, 2012 08:08 PM
texas rebal
Dec 6, 2011 11:01 PM
btmbass
Mar 28, 2011 11:31 PM
tt0876
Suspension Tech
May 5, 2008 11:32 AM
