T bar Alligment Issues
Alright So I cranked my t bars an 1 1/4" about 2 months ago. I just now today got around to getting an alignment which is okay cause I dont drive it much. My tires were wearing evenly and it was driving fine. I took it to a tire shop and had an alignment and they cranked the keys back down to stock ride height. I have 1.5" shackles and the rake was really bad. I have the computerized printoff sheet and all that if anyones curious. Not sure what I should do. Im probably going to crank it an inch and froget about it. I have brand new lowers and I pretty much olny drive it in the late fall, winter, and spring putting maybe 6k on it. Your 2 cents would be appreciated. Thanks, Brian
t-bar +1.25" and got an alignment. i have the same print off. my alignment was off by a BUNCH... but i also totaled a crx with my d side front tire so.... it might factor in. IMO as long as you dont go over 2" over stock, you should be ok. 1.5 = should be fine. 1" no change.
there is always the guy that cranks his t bars +4 and has no problems, and the next guy goes up .75 on one side to fix sag and blows out a cv... do what you like
your not doomed but if the boot is still on i definately drop the t-bars back down. you still might want to replace the axel depending on how long it has been leaking. they usually run 40-50 bucks depending whether you go with a new or reman axel. but in my opinion drop the t-bars back down or you will go through the same thing i did axel after axel. you learn how to do axels really quick when you do it numerous times.
texas rebal
Dec 6, 2011 11:01 PM
