wanna lift a little bit 2 to 4 inches
Old Feb 19, 2014 | 12:32 PM
Bluebeastblazer57's Avatar
Bluebeastblazer57 is on a distinguished road
Default wanna lift a little bit 2 to 4 inches
i would like to lift my 1998 2dr blazer non-zr2 a little bit what is the best way to do it i was thinking tbar up front 2inches and new leafs in back? could i use zr2 springs in back correct me if im wrong
Old Feb 19, 2014 | 01:26 PM
versechorusverse's Avatar
versechorusverse is on a distinguished road
I believe ZR2 springs will fit from a blazer, not pickup. ZR2's gain their height from the suspension being mounted differently not from taller leafs. You could get an add-a-leaf, new leafs, or shackles. I would go with shackles because you keep the same ride stiffness and they are pretty easy to install could get it done in an hour depending on rust, and if you know someone with a welder they could probably do it no problem. Another budget way of doing it is adding leafs from a junkyard vehicle.
I wouldnt crank the TBar too much, but its up to you.
Old Feb 24, 2014 | 01:09 PM
thank you i didnt know that about zr2s. and i think you can safely crank the tbar 2 inches with out problem and ill look in to shackels.
Old Feb 24, 2014 | 01:22 PM
i thought about body lift but is that an okay way to go? i would rather have a suspension lift
Old Feb 24, 2014 | 01:32 PM
Jamaroon's Avatar
what are your goals for the truck?
Old Feb 26, 2014 | 12:02 AM
to give it a small lift to get bigger tires and more clerance
Old Feb 26, 2014 | 06:47 AM
Jamaroon's Avatar
just for looks/ on road driving only? or off road where you will be using all of your suspension travel?
Old Feb 26, 2014 | 03:35 PM
daily driver and off road
Old Feb 26, 2014 | 03:47 PM
Jamaroon's Avatar
Then 2" body lift would give better tire clearance
Old Mar 1, 2014 | 01:35 PM
i will keep that in mind thank you.
Dadatone
Jul 26, 2012 12:28 PM
1hugeblazer
Jul 6, 2012 09:15 PM
2000jimmbo4x4
Lifting Tech
Jan 19, 2011 10:31 AM
97Bravada
Suspension Tech
Mar 20, 2010 10:22 AM
