whats holding it back?
Old Feb 26, 2012 | 12:07 AM
Hunter_Zack_1994's Avatar
Hunter_Zack_1994 is on a distinguished road
Default whats holding it back?
hey guys. a few months ago i tried to put some lift shackles in my 95 blazer, but failed. but when i did it, the leaf spring wouldnt fall all the way down as expected. whats holding it up once the leaf spring bolts are off? and if it is the shock absorber, does that mean i can put a larger shock in and then pull the spring down lower? any imput would be great...im new to this:/
Old Feb 26, 2012 | 12:38 AM
war00's Avatar
war00 is on a distinguished road
yes you need to undo the shock from the spring perch and that will allow you to lower the axle, also remove the wheels so you can drop it even more. yes after you install the shackles you will be able to install longer shocks tho not needed if your only going 1.5"
Old Feb 26, 2012 | 09:58 AM
thankyou! and id like to make it as tall as i can:P will the sway bar ever become an issue? and once i have my new ride height how will i know hhow big a shock to buy?
Old Feb 27, 2012 | 10:46 PM
j89lumaye's Avatar
j89lumaye is on a distinguished road
I just put a bottle jack in between the frame and spring and used it to push them down until i had the holes lined up
jbordi
Mar 25, 2011 06:20 AM
brokencookie
Oct 9, 2010 09:42 PM
Tony H
Apr 6, 2010 12:18 PM
frank29
Mar 2, 2008 03:51 AM
gmyoyo
Nov 7, 2005 02:42 AM
