Would I be able to fit 31s?
Old Jun 11, 2013 | 04:44 AM
Ak609's Avatar
Ak609 is on a distinguished road
My zr2 1999 fits the cooper discovery stt with no rubbing its close though. Even if it flex up into the wheel well. And blaze what roof rack do you have I like it.
Old Jun 11, 2013 | 05:37 AM
newguy's Avatar
And what good are larger tires with no clearance?
Old Jun 11, 2013 | 09:55 AM
El_Beautor's Avatar
Originally Posted by blaz
I mean no disrespect El_Beautor. I have seen people led down the "false" road on many forums. Blazer Forum had a good rep so I just figured I would throw in my 2 cents. I had no time on the first post but I think the Pics always help. I know I needed pics before all of my mods.
Blaz, no disrespect at all. I agree with everything you said, and the pictures you posted will probably help people a lot. It is very unlikely that anyone with a non-ZR2 will fit 31x10'5's with no rubbing and only do a t-bar lift and shackles/AAL. Most will end up rubbing in the exact locations you demonstrated in your pictures. I rubbed the frame and fender with 2 out of 3 sets of 31's I ran with just a T-bar and AAL lift, and the 3rd was undersized I suspect. Once I did the body lift I had no rubbing at all on the fender, but I still rubbed the frame in the exact same spot as the picture you posted.
The key here is that you are driving a ZR2. The discussion has been about non-ZR2 trucks and tire sizes. 31x10.5 is the factory tire size on all ZR2's. The factory tire size on non-ZR2 s-series trucks is 235/70/15 which is about 28.5" tall. That almost 3" difference in tire diameter between a ZR2 and non-ZR2. The ZR2's also have bigger wheel wells and a differently shaped frame. All this allows the ZR2's to run bigger tires with less work.
01blazer16
Tires and Wheels
Nov 2, 2013 07:46 PM
headhunter23
Suspension Tech
Jan 3, 2011 09:55 PM
99blaz
Lifting Tech
14
Feb 22, 2010 09:07 PM
ahawks47
Jan 6, 2010 01:12 PM
slickwilly
Nov 5, 2008 03:50 PM
