02 Blazer ZR2 - Multifunction Switch Pinout?
Old Aug 18, 2013 | 05:22 PM
jrsteensen's Avatar
jrsteensen is on a distinguished road
Default 02 Blazer ZR2 - Multifunction Switch Pinout?
Low beams haven't been working, and I can't get voltage to the control side of the DRL Relay - if I jumper the switch side, the low beams turn on. In dash light switch tested good with a 14V across terminal B & C when I turned it on.
Took apart the steering column to get to the multifunction switch to test it, and was met with something very different than the wiring diagram suggested.
Got the combo switch disconnected from the steering column (mechanically) to expose all the test points on the inside of the steering column. Can anyone get me a pinout of that guy so I can figure out from the wiring diagram which pins to test for voltage? ASAP if possible - got a monsoon rolling in and I want to be buttoned up before it hits. Gotta drive this thing to work tomorrow AM. Thanks!
jimspahr@msn.com
Aug 5, 2017 08:49 AM
sirhc76
Mar 27, 2012 01:42 AM
joe
Jul 5, 2009 06:14 PM
joe
Jun 19, 2007 07:13 PM
mselva
May 16, 2006 04:07 PM
