1996 4 3l v6 alternator wiring
Old Feb 22, 2022 | 01:56 AM
GeorgeLG's Avatar
OK so I am looking at a 1996 4.3L vortec engine donated from a Blazer and now sitting in a 1981 Toyota pickup truck? Where does the Nissan van fit into this situation?
Im trying to help you but there are dozens of alternator wiring set ups that work with different dash electrical circuits, regulators, etc. across all the manufacturers, years and engines and I don’t understand the vehicle and engine combination here. It looks like your connecting two wires to a 4 wire alternator connector and I have no idea where those two wires came from or as I said, what engine this is, it’s year, the vehicle it’s in and it’s year.
George
Old Feb 22, 2022 | 02:29 AM
Brodrdude's Avatar
Brodrdude is on a distinguished road
George
I said nothing about a nissan van. Ive stated it and even the thread name is 1996 4.3l in a blazer forum, how oblivious can you be to not understand what this engine is.
Yes its a 4pin plug thats has only one wire coming out of it. Then I have the post with the red wire going to battery
Old Feb 22, 2022 | 08:22 AM
GeorgeLG's Avatar
I was trying to figure out what NS3500 is and what that has to do with this. Van, transmission, …
You didn’t answer my questions about voltages to see what’s going on with the system so we don’t even know if the alternator is turning on. Some alternators do not just turn on and start charging because the pulley is turning.
It matters what vehicle this is in, the year and style of the alternator and what’s going on with the rest of the wiring because there is more to a working charging system than just getting the output terminal to the battery. The alternator has to turn on and be regulated properly which is what some of the rest of the wires do and there are many different types of systems that do this.
As I mentioned earlier, be careful what you hook directly to the battery, it is capable of delivering hundreds of amps instantly which can be dangerous.
I’m sorry that I was not able to help you. I hope that you get it figured out.
George
Old Feb 22, 2022 | 08:43 AM
Brodrdude's Avatar
George
I put nv3500 is the 5spd manual that they come with. With the voltage 13.5 until 10.5 it dies. it just drops until the jump dies.ive tried at different rpms and still the same out come. Would any of the interior wiring effect the alternator from turning on?
Old Feb 22, 2022 | 09:28 AM
GeorgeLG's Avatar
In some charging systems yes, hence all my questions.
George
Old Feb 22, 2022 | 10:07 AM
GeorgeLG's Avatar
I really like helping people fix their trucks and I was trying to help you but this set up is confusing as to vehicle and year, it’s wiring, engine type (Blazers also have 2.2L engines) and year, it’s alternator and year, 2 wire, 4 wire, etc. and I needed to know the details to get your charging system working. I usually use my electrical engineering degree and 51 years of vehicle rebuilding and repair experience to translate some of this stuff for members here, especially electrical concepts which appear to be some of the most confusing for people. Since you are not happy with my questions and my ability to grasp your situation, I will give you the tools to figure it out yourself. Below is a very comprehensive article on how all of this works, the solution to your problem will be found in these technical details and this is a good reference for future members surfing this thread. It’s way more than most probably want to know about how alternators and charging systems work but some may find it useful. You can have one of many problems:
alternator is dead
alternator is wired wrong
bad belt or improper tension
Vehicle wiring is faulty
battery is faulty
there is no excitation field current at alternator startup to initiate charging
there is improper regulator function to control output
blown rectifier diodes
system load is excessive
etc.
Here is The article, best of luck. Once you master this stuff, you can come back here and help other members fix their electrical problems and you can ask whatever questions you wish:
https://www.pirate4x4.com/threads/12...x-com.2702737/
George
To quote Les, “I’m out”
Old Feb 22, 2022 | 01:26 PM
Brodrdude's Avatar
alternator is dead
battery is faulty
etc.
George
think as a stock standalone. Just basic 1996 4.3l out of a blazer with a 5spd manual. I have "key on" jumped from ign fuse(temporary) so I can get power to everything. Which everything does. Hence the engine does run just not long due to alternator not charging.
the alternator wiring was cut, I was originally asking if I spliced into the right wire for the alternator 4plug harness. Or you can call the voltage sensor wire
Imma hit a junkyard soon and pull an alternator( to eliminate the issue if alternator did failed or it is just wiring) also to look at the stock wiring.
Hopefully this clears up this abit better.
hoebob69
Apr 11, 2015 12:38 AM
NCRD1331
May 22, 2013 12:55 PM
59f-100
Sep 4, 2012 02:03 PM
blazergurl95
May 3, 2011 12:54 PM
brudus420
Apr 29, 2011 06:37 PM
