1999 Chevy Blazer low beams don't work. Checked relay, drl module, fuse, head light
Old Feb 27, 2019 | 11:22 PM
Shilodog's Avatar
Shilodog is on a distinguished road
Default 1999 Chevy Blazer low beams don't work. Checked relay, drl module, fuse, head light
1999 Chevy Blazer low beams don't work, need helpchecked all fuses, relay, drl module, headlights still no low beam
Old Feb 28, 2019 | 12:35 AM
Are the high-beams working in DRL mode or in High-Beam mode?
In DRL mode, the high-beam bulbs are connected in series and when in regular mode they are wired in parallel. The DRL relay is responsible for the change in how the current flows through them. There is also a headlamp grounding relay that must be working properly for the regular low beams and regular high beams to work.
Have you checked these other relays?
Dpinzoner
Dec 31, 2018 07:36 PM
99 blazer
Dec 23, 2015 07:42 AM
Tajohns34
Dec 21, 2015 11:12 AM
NVANZEE
Dec 22, 2008 06:18 AM
portcqb
Oct 9, 2008 06:35 PM
