2002 Blazer BCM not energizing, alternator not charging
Old Aug 21, 2019 | 11:42 AM
VintageIron's Avatar
VintageIron is on a distinguished road
Default 2002 Blazer BCM not energizing, alternator not charging
Hello and thanks for taking time to read this.
I have a 2002 Blazer 4wd that no longer charges the battery, the OBDII port has no signal, and the instrument cluster is blank except for the "Service engine soon" light. I have checked all the fuses they are good, there is 12 volts and good ground at the BCM, OBDII, and Instrument cluster, however I am showing NO continuity between the ECM and the OBDII.
Any suggestions on where to look for the fault are greatly appreciated!
Old Aug 21, 2019 | 03:50 PM
Did you check the fuses and relays under the hood in addition to those in and under the dash?
Old Aug 25, 2019 | 10:07 AM
Thank you for your reply, yes I did.
Layinchromies
Oct 18, 2020 12:12 AM
VintageIron
Jul 7, 2019 04:38 PM
Dadatone
Sep 19, 2012 06:16 PM
kristoph30
Jun 28, 2011 09:27 PM
blzn95
Jan 27, 2009 08:48 AM
