2002 Chevy Blazer headlamps
Old Oct 20, 2022 | 12:52 PM
Rodney gullion's Avatar
Rodney gullion is on a distinguished road
Default 2002 Chevy Blazer headlamps
High beam headlight not working on right side got new elements still would not come on so I'm switch the element from right to left and it was not the element so I got a test light and there was no power going to the high beam right hand side I checked the fuses and moved some relays around and still no luck so for a temporary fix I ran a wire from the high beam on the driver side to the high beam on the passenger side My worry is that I could overload that circuit if it has separate right and left should I go all the way back to the switch and check for power
Old Oct 20, 2022 | 01:35 PM
GeorgeLG's Avatar
OK, that's it, you break the all time single day posting record. Second coffee pot brewing so I can keep up.Lets get your headlights fixed.
Does the low beam work on the right side?
Did you check the "RT Lamp Fuse?
Did you lose ground on Purple or power on Dk Blu or both?
Crap now I have caffeine jittersssssssss.
George
Mkapis
Mar 2, 2019 11:34 AM
dflanigan
Jan 3, 2014 06:06 PM
Mike4x4ing
Jul 6, 2013 01:21 PM
