3rd Brake light not getting power. Fuse? Where is it?
Old Nov 18, 2013 | 08:56 PM
iian's Avatar
iian is on a distinguished road
Originally Posted by dempsey
iian, are you testing for current by putting a probe in the wire and the other to a ground, because if so this is how you would test for voltage (in parallel). Sorry if you are doing it correctly, it just seems by the way you wrote your message that you are testing for current in parallel. Current needs to be in series with circuit. If so try checking the voltage to see if you are getting a voltage drop.
I had an issue with my 3rd light and replacing it seemed to do the trick because I was getting voltage to the light, but it wasn't turning on when I stepped on the brake.
best of luck trying to figure it out, electrical stuff can be a pain sometimes.
I am using a 12v test light. Probe to the power wire, other to ground on the vehicle. Using tire iron to wedge between the brake pedal and the seat.
I am not getting power to the 3rd brake light. Bought a new light strip, plugged it in and nothing. Thought maybe it was defective, so got out the test light and tested the yellowish/white wire and no power is getting to the brake light. Are you saying I need to probe the black wire and yellow wire at the brake light connector where it plugs in at?
The more I think about what Richphotos is saying about tapping into the brake light switch to get power is confusing me. Why would I not be able to tap into the white wire near the tail lights instead of getting it from the brake light switch itself? If there is a white power wire at the switch and also at the tail lights, would I not be able to tap it there? Or does the turn signals somehow get routed and run back to the white wire at the tail lights?
Sorry I am making this more difficult than it needs to be.
These last two pictures were borrowed from the thread I posted about the Euro tail light thread showing where he tapped into.
Attached Thumbnails 3rd Brake light not getting power. Fuse? Where is it?-i-1.jpg   3rd Brake light not getting power. Fuse? Where is it?-i-2.jpg
Old Nov 18, 2013 | 10:27 PM
dempsey's Avatar
dempsey is on a distinguished road
No you are using the test light correctly, I forget what wire is power on the brake light but that is testing the voltage not current that is why I got confused. one of the wires should be probed and the should be grounded ( make sure it has good contact with bare metal).
I'm not to fimilar with what richphotos is talking about because I didnt have that problem with mine but it makes what he said about it blinking when you directional is on.
You might have a pinched wire somewhere and grounding the circuit out.
You could always test that wire with the probe and put your directional and see if the test light blinks. If it does you would have to run a new most likely and if doesn't blink and turn the test light on only with the pedal then use. That's what I would say.
Old Nov 18, 2013 | 10:40 PM
richphotos's Avatar
I was talking about it blinking if you were to tap into the passenger side or drivers side brake light to get the 3rd brake light to work.
Since there are only 3 wires per socket on the brake light sockets (brake/signal, running, and then ground) Each time you would turn the signal on for the side you tapped into, the 3rd brake light would start to flash.
Finding a short by checking ohms ect, would tell you if there is a short, but after that, finding where the short is, would be more trouble than just finding 10ft of 16 gauge wire and tapping into just after the brake light switch under the dash.
Most of the time they run the brake light wires through the body panels up to the front. You would have to basically pull apart your whole interior on the side the 3rd brake light power wire runs up.
dano440
Jun 20, 2012 04:57 PM
dano440
May 11, 2012 06:57 PM
steveshane67
Jan 28, 2010 05:06 PM
drperry
Aug 16, 2009 05:24 PM
magnum434
Sep 30, 2006 02:03 PM
