4wd encoder/ fuel sender issues related 2000 blazer
Old Nov 18, 2020 | 03:28 AM
obscene's Avatar
obscene is on a distinguished road
Default 4wd encoder/ fuel sender issues related 2000 blazer
Ok I've been chasing this issue for a while. All issues were there when I bought this
1st issue
P0463. Sender is good. Issue is I'm reading 12 volts on the purple wire at the pump. Reading 5v on reference wire off of the pcm which is where it should be.
2nd issue
4wd service light has been on since I bought it. The code was a b1346. Encoder motor chassis ground #1 circuit range performance. There are no lights illuminated on the 4 button switch.
While trying to figure out the fuel sender p0463 issue I followed the purple wire to the encoder motor. So I found where I think it has changed from 5v reference to 12v.
would a bad encoder motor cause this? Or do I have an electrical issue/ bad ground somewhere. Any help is appreciated.
Thanks guys!!!!
Old Nov 23, 2020 | 10:14 PM
obscene's Avatar
Default Fixed
Spoiler
who ever owned this before me sucked at auto mechanics lol. Didn't really help that Chevrolet would put multiple plugs in close locations to each other that plug into other locations.
the 6 pin connector plugged into encoder was supposed to be plugged into a plug that comes down with the o2 sensor.
The encoder plug was tucked up above the transmission unplugged. The speed sensors were swapped around so this plug wouldn't reach the encoder.
With everything plugged into the proper locations everything works as should!!!!
Old Nov 24, 2020 | 05:22 AM
Oh boy lol... glad its fixed!
LesMyer
38
Jan 9, 2020 11:45 AM
Matthew Ackerson
Sep 27, 2017 05:28 PM
tracy142006
Oct 23, 2012 05:12 PM
96jimmy4x4in
Sep 15, 2008 11:06 AM
CaboKP
Jan 27, 2007 03:44 PM
