'95 Blazer, one light dim
Old Sep 24, 2011 | 07:29 PM
cleburne red's Avatar
Default '95 Blazer, one light dim
I have a '95 Blazer LT. My passenger headlight is very dim when I turn on my headlights. The driver's side works fine, though. Also, when I turn on the headlights, the right turn signal indicator come on in the instrument cluster and stays lit. The right turn signal light on the front also is not lit when the headlights are turned on, however, the left one is.
I thought it might be a fuse/relay; I know that sometimes when one headlight fuse goes, there is a safety feature that will send a small amount of current to it anyway. I can't find any information about where the relay is located. None of the fuses in the fuse box are for headlights. I've checked in the relay box inside the glove box, but there are only two relays, and pulling either of them does nothing to the headlights.
Is there another relay box I'm missing, or what?
Thanks for any help. This is my first post to this forum, but I've been reading it for awhile, and have learned a lot about the 4wd toy, i.e. money pit I just bought.
Old Sep 24, 2011 | 08:30 PM
bromanjr's Avatar
bromanjr is on a distinguished road
The Grounds for the lights on each side are grounded by a sheet metal bolt into the Radiator Support. The one for the passenger side is below the battery. Probably very corroded or broken.
Old Sep 25, 2011 | 08:09 PM
Thanks for the suggestion, haven't had a chance to look yet, but I'll check it out.
Old Sep 27, 2011 | 07:47 PM
Well, it was the grounds. Only it wasn't that they were corroded, they just weren't attached to anything! I couldn't find the grounds anywhere around the core support, so I removed the battery and battery tray. There were two, both laying below the battery tray, unattached to anything. I pulled them to the side, and put the battery back in. Then, with the headlights on, I grounded them out. The light immediately brightened! I'll clean them up and bolt them to something. Thanks for the help!
Edvalle10
Feb 12, 2015 09:59 AM
jimspahr@msn.com
Jul 4, 2013 06:24 PM
NUM-1-GM-FAN
Apr 22, 2010 08:04 PM
cmmyers10
Dec 19, 2006 03:43 PM
jaleg
Nov 17, 2004 02:53 PM
