99 Blazer Power Window Lock Switch
Old Sep 5, 2011 | 03:58 PM
Mike99BlazerLT's Avatar
Mike99BlazerLT is on a distinguished road
Default 99 Blazer Power Window Lock Switch
I just bought a 99 Blazer LT. All the power windows work, but only from the driver's controls. I made sure that the window lock wasn't on and still none of the other doors can control their own windows, to go up or down.
Could this be as easy as just replacing the window lock switch (is that easy even?), or could this be something more serious? I inspected the fuses already, not sure what the next step in dignosing will be...
Thanks for the help,
-Mike
Old Sep 5, 2011 | 04:23 PM
bromanjr's Avatar
bromanjr is on a distinguished road
-Mike
You are correct, the only component between power and the passenger switches is the lockout switch. I have seen them installed backwards in the bezel try both positions.
Old Sep 5, 2011 | 04:30 PM
I've tried both positions already, first thing I did actually. It sounds like the switch might just need to be replaced.
Any other ideas before I just go ahead and but a new switch?
Thanks for the help.
Old Sep 5, 2011 | 04:32 PM
bromanjr's Avatar
unplug the connector and put a jumper between the wires, should work then or it's not the switch.
Old Sep 6, 2011 | 12:25 PM
There are 4 wires that connect through a harness, a Blue, Brown, Green, and Black. Do you know which wires to bridge together to test this?
Thanks
Old Sep 6, 2011 | 01:42 PM
I pulled the switch and cleaned up the connectors and it worked!
Thanks for all the help guys...
HigherPower
15
May 5, 2011 11:25 PM
ussexplorer
Apr 16, 2010 04:49 PM
rossg
May 27, 2009 07:48 AM
Spiffy
Sep 15, 2008 04:37 PM
muszyngr
Apr 23, 2008 02:55 AM
