99 blazer two door 4x4 lights shut off when pressing in the clutch
Old Aug 11, 2019 | 12:35 AM
Standingfast5150's Avatar
Standingfast5150 is on a distinguished road
Default 99 blazer two door 4x4 lights shut off when pressing in the clutch
So when i bought this blazer only the brights worked and then they stopped completely after checking fuses and relay everything was good so i went and bought the multi switch in steering coloum and as i pull up to my fathers house to do the repair i press in the clutch and headlights come on i let off the clutch and they turn off so i then peel back the floorboard carpet and there is a arms thick worth of wire going to colom and back into dash and under the seat .the arm of clutch lever is pushing or pulling on this and all three sections of wire harness moves but its moving the whole thing maybe a millimeter .part of the harness that goes to stearing colum has a connection block at the base i think its a loose pin maybe if you try and move the wires its so tight that you move all three sections so i cant tell what group is the cause . and now they dont come on at all so how do i go from here .
cas
Apr 25, 2017 08:41 PM
rblake
Nov 12, 2011 08:31 PM
grandboost98
Aug 2, 2010 03:02 PM
Chevy Lover
Aug 2, 2007 11:06 AM
SDimeBlazerlady
Sep 17, 2006 05:43 PM
