Adding a set of LED blinkers
Old Jul 10, 2013 | 05:24 PM
Badco's Avatar
Badco is on a distinguished road
Default Adding a set of LED blinkers
So I got some mountable strips of LEDs the other day, and I've heard about having to put resistors and stuff in them when you wire them up? I'm by no means an electrician so bear with me here.
My original plan was to splice the blinker wire and run it to each LED which would be mounted on both sides of the back window... Maybe... I think. These are the strips and the operating voltage is 9-14.8 volts. Am I going to need anything at radioshack? They'll be here on Friday so that gives me plenty of time to figure out this electrical thing.
Old Jul 10, 2013 | 10:07 PM
richphotos's Avatar
They will work without a resistor, but if you want them just as blinkers, there is no "just blinker wire" blinker and brake light are ran on the same circuit. so the lights will function as both.
Old Jul 11, 2013 | 01:17 AM
Thogert's Avatar
If you are keeping the stock tail lights, then you won't need any resistors like rich said.
Old Jul 11, 2013 | 06:07 AM
Badco's Avatar
If thats the case I may try and do something different. I'd like them to be dedicated turn signal lights, yellow is hardly my idea of a stop light. Are the brake light and turn signal activators run off the same unit?
USPS says they've arrived at my local post office. Exciting!
Old Jul 11, 2013 | 12:33 PM
richphotos's Avatar
Hopefully someone can chime in on this one.
Start doing some extensive searching on the net to see how people in the US are wiring up brazilian blazer tail lights. Those tails have separate amber turn signals.
Old Jul 11, 2013 | 05:11 PM
Badco's Avatar
According to this thread I'll be wiring them from the front..... No problem though. A few measurements and they should be done.
Heres a picture of em! The clips are not exactly what i expected for something that claimed to be waterproof... Only about a foot in length too. But that's okay!
Attached Thumbnails Adding a set of LED blinkers-1002438_687122631314072_1849396708_n.jpg
Old Jul 11, 2013 | 08:00 PM
Thogert's Avatar
You could tap into the trailer plug.
Old Jul 11, 2013 | 09:20 PM
Badco's Avatar
The way I read it, the trailer blinkers are wired ala the brake lights? I totally passed on thinking about the trailer wiring, but some googling has led me to this. This has a lot of info on trailers in General, as well, but this seems to be the gold I was looking for...
Color codes
White or black is the ground.
Green is right turn.
Yellow is left turn
Brown is tail lights.
I'll be digging in after work tomorrow. I'll be sure to take some pics. And since it's dark I got to see the UV cabin light. Lit it up! The 562 was slightly too big, but I was able to wiggle it in without any funky sounds.
Sorry, this bulb was the 578.
Old Jul 11, 2013 | 11:18 PM
richphotos's Avatar
There you go, I was going to say, I am not sure the front blinkers would work, as they are similar to the tails and use a 1157 bulb, dim with the parking lights, and go to full brightness with the blinkers.
Your best bet would be like thog said and go from the diagram you found on AF and wire it up to the trailer harness, and you should be good than.
Old Jul 12, 2013 | 12:31 AM
Thogert's Avatar
I always wanted to play with UV leds. Would you mind getting a pic of how that looks?
I thought it would be cool to get fluorescent paint and do the trim in that with the UV light.
