Air bag light
Just recently I'm driving along and I had the air bag light go on briefly. At the same time there was a beep inside the dash AND it felt like the car was going to stall. This happened to my daughter while she was driving it, only it did stall.... complete shut down while driving, but started right back up again. Thanks for the help.
Could be the initial signs of an ignition switch failure. You could have the airbag codes read to see if anything was stored.
Does that require a sophisticated reader like at a dealer? Thanks.
It does require an enhanced (full feature) scan tool, but the dealer isn't your only option.
mine has been going off and on too, i probably won't bother getting it fixed
Well I never made it to get the Air bag code read. Blazer died and won't start at all.Turns over....sounds like it wants to start, but won't. Had to have it towed. Everything shut off while I was driving along. Good thing I was only driving 35 mph! Well..........I need a educated guess on this problem, cause it's at my house and I plan on fixing this myself. Would you say that it's most likely the ignition switch? I know there is no way knowing that's it 100% but I just want odds. Thanks for the advice.
You may be experiencing an ignition switch failure. That could link all of the issues you are experiencing together.
You could check all of the grounds and splice packs under the dash to be certain that it isn't just a grounding problem as a next step before replacing the ignition switch.
Thanks will do, then post back.
Well I checked everything the best I could under the dash. Everything looks ok. I want to go in and replace the ignition switch. 97's had problems with the ignition switch anyways I believe. Any step by step posted proceedures on doing this successfully? Thanks.
