alarm goes off by itself all the time
Old Jul 27, 2011 | 07:52 PM
kennystorie's Avatar
kennystorie is on a distinguished road
Default alarm goes off by itself all the time
i have a 2000 blazer LT .The alarm goes off all the time on its own and the keyless remote does not work and the auto illumination does not work and the interior globe light does not work unless u turn it on maually in other words it doesnt come on when door is opened.. what could be causing all of this?
Old Jul 27, 2011 | 09:11 PM
xgiovannix12's Avatar
sounds like your alarm system went poof or theres a short some where in the alarm
Old Jul 28, 2011 | 08:12 AM
Bowtiefly's Avatar
Bowtiefly is on a distinguished road
Default Reseting the door locks and alarm
I was having this problem yesterday i have electric door locks and i found in my owners manual a way to reset this problem.
first put the key in the ingnition in the off position.
Next pull the turn signal toward you hold it there now turn the ignition on and off two times. after the second time release the turn signal.
after you release the turn signal you have 30 seconds to program the alarm and door locks Note the following steps are the choices you have and you can only do one at a time within 30 seconds of releasing the turn signal lever
A. All doors lock drivers door unlocks only press the lock side of the power lock once and then the unlock side once.
B. All doors lock and unlock. Press the lock side of the power lock switch once. And then press the unlock side twice.
C. All doors lock no doors unlock
Press the lock side of the power door lock switch once and the unlock side three times.
D. No doors lock no doors unlock ( Factory setting )
I hope this helps it reset the alarm on my 2001 Zr2 blazer
I am not saying it will work i am only trying to help.
Old Jul 28, 2011 | 10:16 AM
NVANZEE's Avatar
It could also be a bad door switch. I had that problem on a 2000 bravada. So when its locked it will randomly think the door is being opened causing the alarm to go off
Old Jul 29, 2011 | 01:40 PM
yhanks guys i will try to reprogram it first then i will replace the door switch if it dont work thanks again
Old Jul 29, 2011 | 01:41 PM
thanks guys i will try your suggestions i hope 1 of them works.
Old Jan 18, 2012 | 05:18 AM
heartattack's Avatar
heartattack is on a distinguished road
kenny, did you have any luck with the alarm, just wondered as mine's doing the same.
Old Mar 19, 2012 | 09:44 PM
jcervantes's Avatar
jcervantes is on a distinguished road
I have a 99 blazer LT, the alarm goes off every time i lock it i tried everything, like taking off the lock controls and checking them and checking the fuses, a neighbor told me to disconnect the battery and connect it again tried it it didnt work so now i got my blazer going off int the middle of the night. I forgot to say that before all of this a big storm came around i wonder if water got in the electrical wiring
droidxusa
Aug 20, 2012 08:16 PM
skid9832004
Suspension Tech
Aug 3, 2012 11:25 AM
julioAKAjunior
May 4, 2012 05:12 PM
Greatestsin
Aug 20, 2009 01:05 AM
cr8390
Jan 17, 2009 05:04 PM
