Anyone else have flickering lights?
Old Nov 12, 2010 | 03:00 PM
blazinloud's Avatar
Default Anyone else have flickering lights?
According to this thread http://www.zr2usa.com/mboard/index.p...pic=27862&st=0
if you put bigger/better grounds on your battery that it can cause all lights on your ride to kind of flicker a bit without change in voltage on the battery.
I have noticed that mine will do this sometimes when im idling at night, although mine dosent sound as bad as the original posters.
Now they talk about adding a "sensing" wire from one of the plugs on the alternator harness to the alternator post and completely solved his flicker, and helped him hold a steadier voltage, rather than fluctuating back and forth on the gauge like mine does.
I have the 4 pin connector but only 1 red wire coming out of it.
does anyone have input on this?
Old Nov 12, 2010 | 03:20 PM
This is likely an issue caused with the PWM circuitry inside the PCM. I have had this happen on a lot of vehicles. The post at the bottom of page 1 in that thread details what is required to change the alternator from PCM control to the old steady state control.
Old Nov 12, 2010 | 04:04 PM
blazinloud's Avatar
they also list ac delco part number-pt1136 which looks like this http://carphotos.cardomain.com/ride_...0094_large.jpg
4 wire alt. harness. so for install one would have to cut the original red wire on the original harness, solder together then run the wire/pin thats supposedly marked "S" to the alt. bolt and your done?
are the any pro's or con's to doing this other than the flickering light problem?
Old Nov 15, 2010 | 04:02 PM
blazinloud's Avatar
checked my alt. connection and it only has 1 of those silver prongs that make the contact, guess id have to replace mine with the other harness.
also i didnt see any markings saying which pin was which
Old Dec 6, 2010 | 02:47 PM
bluiewest1's Avatar
bluiewest1 is an unknown quantity at this point
My interior and dash lights have been flickering for a while, but recently the headlights have started dimming briefly when I step on the brakes or use the turn signals. The voltage indicator shows something around 15v , and that is if the dash gauge is accurate. I guess the next thing would be to check the alternator output with a volt/ohm meter?
newguy
Feb 18, 2013 11:25 PM
Thogert
Jul 5, 2012 01:18 PM
BlazHerZR2
Jul 1, 2011 12:33 PM
philip_king
Dec 8, 2009 07:03 AM
USMaverick101
Mar 28, 2007 07:55 AM
