Best thing to keep battery cables from coroding every few days
Old Apr 6, 2019 | 09:26 PM
Arkie blazin's Avatar
Arkie blazin is on a distinguished road
Default Best thing to keep battery cables from coroding every few days
What should I use to keep my battery cables from cording every week or two
Old Apr 6, 2019 | 09:31 PM
cleburne red's Avatar
Which terminal? Could mean the battery is under charging or overcharging depending on which side is corroded
Old Apr 7, 2019 | 04:18 AM
Default Battery cables
Its always the hot side that gets coroded.
Old Apr 7, 2019 | 08:49 AM
According to Google, that means it's overcharging.
I would make sure the post and terminal are clean, tight, and making a good connection.
How old is the battery? If it's leaking, might speed up the corrosion. Maybe time for a new one
Old Apr 7, 2019 | 11:35 AM
rriddle3's Avatar
*Moved to 'Lighting & Electrical'*
After you have thoroughly cleaned both the posts and cable clamps, coat them with Vasoline to protect them from corrosion.
Old Apr 13, 2019 | 12:09 PM
Thank you
99blazerdog
Feb 3, 2021 07:20 AM
blazz
Dec 14, 2017 11:48 AM
Steve-o
Feb 12, 2014 06:27 AM
SDimeBlazerlady
Dec 30, 2006 03:43 AM
blazerscooby
May 3, 2006 11:25 AM
